Old-Biscuit
Jun 07, 2015Explorer III
Tire pressures are to be set COLD and then forget about it until next time to check them COLD.
Elevation changes pressure and heat changes pressures......all of these changes are engineered into tire by mfg.
Set tires COLD and forget about the rise in pressure while driving.
If you didn't have (when you didn't have) that TPMS you would set tire pressure COLD and then GO..........n0w you have more info that is confusing you. :B
