pbeverly's avatar
pbeverly
Nomad II
Sep 03, 2023
TPMS - Tire Pressure Increase
Tire pressure increases while traveling. In researching I have seen where a 25% increase in pressure is fine. So at 65PSI I could expect to see pressure up to around around 81 and all should be good.
Any thoughts on this?
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    CapriRacer wrote:
    ktmrfs wrote:
    This week on our trip I took a look at tire pressure/temp. In the morning before starting one tire 63psi, 55F. After about 30 minutes of driving and outside temps up to 65F, that tire was at 78psi, and 90F. Other tires basically same pattern. Now the "sunny side" of the trailer had tire temps noticeably hotter, 10F or so. and higher pressure as well likely from heat absorption from the sun hitting the black tire.
    Now if outside temps hit 90F, I would expect a slight increase in pressure, most of the pressure increase is due to friction induced heat.
    Now, the other unkown is how accurate is the temp reading for a TPMS?? Is it measuring rim temp? air temp? or some combo.
    And then factor in how dry the air in the tire is. If it is dry, Boyles law works nice. if there is moisture (water) especially if it condenses, pressure will bump up noticeably once it become a vapor. which is a strong function of temperature.
    First, water: Unless you have a pool of water in the tire, you can treat ALL the gases in the tire according to the Ideal Gas Law:
    PV=nRT (Note Boyle's Law is about the pressure-volume relationship and does not include temperature as part of the law. Unless the tire is expanding, you shouldn't be using Boyle's Law.)
    For practical purposes you will hardly ever see liquid water inside a tire. Not only does water evaporate, but the rubber is permeable to water vapor - and the partial pressure equalizes to the outside air. It takes time for gases to migrate in and out of a tire, so even when it is raining, the amount of water vapor in the tire only SLOWLY rises. Meaning you can neglect the effect water might have on the equation.
    The rule of thumb is that tires don't like more than a 10% pressure buildup excluding ambient temperature effects (2% for every 10°F).
    Doing the math. the ambient temperature ride from 55°F to 65°F results in a 1.3 psi in a 63 psi tire. So deducting the ambient temperature effect, you have a pressure build up from 63 psi to 77 psi = +22%. Not good.
    Best guess is that the temperature sensor is reading the temperature where it is located - not the average temp of the pressurized air, nor the ambient air - but you should check with the TPMS manufacturer to be sure.
    the tire pressure on my denali truck doing the towing saw a slightly lower but more than 10% increase in pressure. rears started at 70 front and 65 rear and rose to about 82-85 rear and 75 front. This is typical rise I see towing or not.
    And similar % increase on our Acura MDX hybrid.
    And with constant volume boyles law indicates pressure increase with temperature. PV=nRT. V stays constant, T goes up therefore P must also go up. But remember T is in Kelvin, so "room temp" is about 275K, and 100F is about 300K, or if V changes with constant temperature P must also change.
    Now ST tires have a pretty stiff sidewall, not sure how it compares to my LT LRE truck tires, but the stiff sidewall likely results in an increase in rolling friction compared to a non ST tire= higher temps= higher pressure % increase
    Now, it's clear the tpms temperature is not a good indicator of what the actual temperature of the tire air temp, it's definitely higher.
    On another note, temp outside today has been pretty constant at 75F. We are back from a trip and cleaning out the trailer and I checked tire pressure getting it ready to put away. Adjusted them all to 65psi this morning This afternoon, the tires on the sunny side the pressure had risen to 70, tire sidewall is definitely very warm to the touch. Cool side of the trailer is still at 65/66.
    Which is why I check tire pressure either after the vehicle has set in the garage overnight, or if outside only after the tires have cooled and been in the shade for plenty of time.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    And then factor in how dry the air in the tire is. If it is dry, boyles law works nice. if there is moistue (water) expecially if it condenses, pressure will bump up noticeably once it become a vapor. which is a strong function of temperature.
    When I was on the road pulling non rv trailers for living we had no TPMS or inferred temp guns.
    We used a tire thumper at every stop and felt the tires by hand looking for one that was much hotter or low pressure.
    If one tire is hotter than the others check its pressure.
    Several of reasons one tire may run hot and higher psi that a nominal pressure/temps of tires on that vehicle.
  • That is what I forgot in post before yours, external factors like sunshine on tire, exaustpipe pointed at tire, severe braking, etc.
    When descending the mountains, and using the brakes to often, the heat of brakes, transported trough the rimms to tire inside, can rise it to boiling point of water, 100 degr C/212 degr F, with the pressure rising to 87.3psi dry and 101psi wet is more then 50% pressure rising from 65 psi at 65 degr F.
    Then still dont let out air, a healty tire can stand that pressure, and tire material mayby still wont go overheated, because low speed and lesser deflection, so lesser heatproduction.
    If you still think it scary on a hot day, you better use lower speed then lower the pressure ( wich you never must do, not warm, not cold).
  • Also remember that this time of year on a long run the sunny side can have a significant difference from the shady side.
  • I used my made tirepresure/temperature-calculator for wet and dry gascompound.
    65psi at 65 degr F. measured rising to 81 psi, means a temperature in tire of 170 degr F. if dry gascompound, and 149 degr F. If enaugh water in tire, like with normal air filled.
    So if filled with Nitrogen 25% pressure rising is to much, but if filled with normal air, on a hot day its OK.
    I once estimated that on a hot day of 100 degr F. the temp in tire is allowed to rise to 160 degr F, on a 70 degr F day driving 140 degr F in tire max.gives rising to 76.4psi dry and 78.9psi wet is about 20% rising.
    Then tire-material wont go over its critical temperature of by me estimated 300 degr F.
    And not overheating any part of tire-material is main goal of tirepressure determination.
    So never blead down a hot tire, as already written, even dont anticipate on " to high pressure by filling lower cold pressure.
    And I want to go a bit further, but" tirespecialists" dont agree with me.
    Let the cold pressure flow with ambiënt temperature, so dont lower it to determined best at 100 degr F. ambiënt temperature, even if above maxloadpressure of tire, yours 65psi.
    The tire needs the higher pressure to give lesser heatproduction, because cooling down is also lesser, because of lesser temperature-differences between tire-material and air in and out tire.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    And pressure should be set with the tire(s) at ambient temperature, NEVER vent a hot tire thinking it is overinflated!!!
    An increase in ambient temperature will increase pressure (PV=rT) V (volume is constant, so if T increases, so does P) And rolling resistance of the tires creates friction which increases temperature.
    And yes 20-25% is possible, I usually see around 15%
  • Bobbo's avatar
    Bobbo
    Explorer III
    What you post is absolutely true. Also, hot days increase pressure. I set my high pressure limit at 20% over the inflation pressure, so your 25% figure is well within reason.
