pbeverly wrote:
Tire pressure increases while traveling. In researching I have seen where a 25% increase in pressure is fine. So at 65PSI I could expect to see pressure up to around around 81 and all should be good.
Any thoughts on this?
When I was on the road pulling non rv trailers for living we had no TPMS or inferred temp guns.
We used a tire thumper at every stop and felt the tires by hand looking for one that was much hotter or low pressure.
If one tire is hotter than the others check its pressure.
Several of reasons one tire may run hot and higher psi that a nominal pressure/temps of tires on that vehicle.
