Dutch_12078
Mar 30, 2019Explorer III
PGCR wrote:
Whatever you get, ensure you get flow-thru sensors so you can check (and adjust) your tire pressure every morning prior to departing for the day.
I just turn on our TST monitor an hour or so before departure to get the current readings. Some TPMS sensors stay in a sleep mode until the wheels start turning, but the TST sensors updatte every ~5 minutes even while sitting still. A visual tire inspection is part of my normal pre-departure walk around routine. I prefer the smaller valve cap style sensors that are lighter and as easy to remove for airing up as standard valve caps once you remove the useless rotating security covers.
38,766 PostsLatest Activity: Jan 10, 2026
