GMandJM wrote:
hanzfranz60 wrote:
If these are the external mount type, try moving that sensor to another tire and see if the same discrepancy happens with the replacement unit.
^This, but it's likely just normal difference between inside and outside tire. Was there also a temp difference?
The temp's were a lot closer I don't remember exact numbers. It was just strange that it's the inside duel that the pressure goes up more on, away from the sun. I might try moving that sensor to another tire and see what happens.. Thanks
