dramsey1ExplorerAug 28, 2017Tire Pressure Monitoring System QuestionI have the TireMinder TM77 pressure monitoring system and am getting ready to install the transmitters the rear duals. To catch the outside tires (which are mounted with the valve stems on the inside)...Show More
John_WayneExplorer IIAug 28, 2017Next time you change tires get the dually valves installed and you will not have to use extenders.
Related ContentTire pressure monitor systemsTire pressure monitorsTire Pressure Monitoring SystemTire pressure monitorTire Pressure Monitoring
