TCmart's avatar
TCmart
Tire pressure monitoring system
Hi all. Looking to install a TPMS on our 2000 Bounder gasser. Got some info on TST system with flo thru sensors. What are the recommendations?
We are looking at 10 sensors for the rig and our tow dolly and toad.
Thanks.
  • Effy's avatar
    Effy
    Explorer II
    I have the TST flow through system and really like it. They have awesome support as well. I had an issue with 2 sensors not actually working to air up with the flow through. And one was showing an incorrect psi. I called TST and we did a test over the phone on another vehicle and they worked fine. Turns out the issue is the valve extenders. Apparently some extenders (and I've had issues with those before) don't relay the pressure correctly to the sensor. Not to mention it's a longer reach for the temp as well. So it turns out the sensors are fine but they don't always play well with the extenders. Have to see if I can mount them directly and get rid of the extenders. I wouldn't have an RV without a TPMS.
  • I also have been pleased with the TST system for about 5 years now. I opted for the model 507 due to the smaller size of the wheel transmitters and the ability to change the batteries myself.
    Lou
    05 Travel Supreme Envoy
