- karlstreamExplorerI bought one of the $60 units on eBay as I wanted to keep track of what's going on with the rear duals. I can't remember what the upper limit is but I run the rear tires at 80 psi. They work their way up to 95psi when the tires get hot.
So far they seem to work fine.
karl - 2oldmanExplorer II
maillemaker wrote:
I see your point there. But poor quality has a way of catching up with you.
When your options are "No TPMS", "$100 TPMS", and "$300 TPMS", which is the best deal if you don't have $300?e
If you truly do not have the $300, that's one thing, but if the word "overpriced" is rolling around in there, that's different. Good luck. - maillemakerExplorer
Which products do you think have the most likelihood of being good quality, cheap ones, or expensive ones?
Expensive ones.
Yet I still buy tools at Harbor Freight, because very often, you don't need top-of-the-line quality to get something that works just fine.
Steve - 2oldmanExplorer II
I think they see "RV" and think they are mostly rich people who throw dollars at problems thinking if it's expensive it must be good. - maillemakerExplorerVendor says you can't combine them in the same vehicle.
Steve - maillemakerExplorer
Looks like it may be good for only up to 73PSI
Most RV carry more then that.
My RV is 65 PSI max so no problem for me.
Steve - klutchdustExplorer II
IAMICHABOD wrote:
klutchdust wrote:
I usually read the one star reviews first and then consider the product before purchasing . The items that failed and why are sometimes a good indication of what to consider before buying.
Great Idea I also do the same then I check with Fakespot you will be surprised by the results.
There are ads running on CL that offer free products if you give 5 star reviews and have a Amazon account. How is that for reputable companies.
Do your homework so you can make a reasonable decision. Thanks for the heads up on fakespot... - IAMICHABODExplorer III
Great Idea I also do the same then I check with Fakespot you will be surprised by the results. - klutchdustExplorer II
2oldman wrote:
Everything works ok for awhile.
Exactly. Consider the cost of one tire VS an inexpensive monitoring system. As far as reviews, I usually read the one star reviews first and then consider the product before purchasing . The items that failed and why are sometimes a good indication of what to consider before buying.
Be safe and have fun..... - Triker33ExplorerLooks like it may be good for only up to 73PSI
38,769 PostsLatest Activity: Mar 28, 2026
