deluco
Jul 11, 2013Explorer
joema62 wrote:
I have reviewed 4 different tire pressure monitoring systems for our Class A RV. These include Pressure Pro, Doran Tire Pressure, Tire Stat, and Tire Sentry. I am totally confused. Has anyone had experience with any of these or can you recommend one I haven't found. I would appreciate any feedback
I just purchased and installed the Tire Minder...
Tire Minder
So far it is very easy to install and works very well. I like that the transmitters have replaceable batteries. The first system I purchased had three of the six transmitters go bad after two years and you have to purchase them in pairs at $50 each. I ended up throwing it away. That was the TST Tire Pressure Monitor System..I don't recommend it...
TST TPMS
It would often take a very long time for the receiver to display the information on tires...also one transmitter went bad within a year..replaced under warranty. Then after another couple of years three went bad. That's when I trashed the system.
The Tire Minder kit I purchased comes with six transmitters AND an amplifier if you need it. I didn't need the amplifier. It reads the transmitter information immediately, although several of the pressures are off by a couple of pounds, it's within tolerances because it won't warn you 'til you are under by 10% less than the original pressure. Also has a warning when the pressure drops quickly (flat or blowout).
38,778 PostsLatest Activity: Jun 10, 2026
