jadatis
Jul 21, 2014Explorer
Tonijim wrote:
Just put four Bilstein HDs on our 2010 Freedom Elite 31R at 22,000 miles. Currently carrying 60psi front and rear. No extra weight being carried and no toad this trip. Am I carrying the best pressure on the new shocks for the best ride?
Any thoughts would be appreciated.
Jim
As long as you did not weigh , we have to go from GAWR's because even empty a motorhome is already close to its maximum weight.
so you think the weight on wheels is way below half of GAWR ( gross axle weight rating) but practice prooves that mostly you are around that GAWR half.
So to let me calculate a safe lowest pressure I need those GAWR's wich can mostly be found on same plate as the original pressure advices.
Also configuration of vehicle like number of axles and tires on the ground front and back.
Also give GVWR ( G vehicle WR) .
From tires the maximum load or loadindex ( single and Dual) and pressure needed for that , read from the sidewall , but also handy is if you give the maximum speed or speedrating of tire ( J= 100km/62m/h, N=140km/87m/h, Q and higher is 160km/99m/h to calculate with).
Give this and I will calculate and give a picture of filled in spreadsheet in my answer.
38,777 PostsLatest Activity: Jun 28, 2025
