Dog_Trainer's avatar
Dog_Trainer
Tire pressure valve cover indicators
Has anyone had any success with the tire cap valve covers that are for certain pressues on tires. Theses are the ones that have a green indicator that goes to red when the tire pressure goes from the valve cap value to about 20% low. I had them on my TT some time ago and they were fine. I was wondering if they were suitable for a class A that normally operates at 90 psi.
BTW I do know that the tpms is a better way so don't kneed that advise in this particular case.
  • This reminds me of those pass/fail battery testers for home use. I'd rather have a little more information...
  • Not sure if those are the same brand, but we had them on our fire trucks with many failures. We tried a couple different brands with similar results. We ended up removing them. I had a set on my travel trailer, altough I did not have a failure I took them off anyway to avoid one.
  • Sorry, I’m not a fan and I don’t trust pressure gauges either. I use two and replace them regularly.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Had them blow out and flatten a car tire. Had to take the MOtor home over (only other vehicle at teh time) with air compressor. and then got stuck and had to call for a tow to get unstuck, Tow company sent about half enough wrecker so had to use my strong mind and his weak back to get 'er out.
  • I have them on my class C. A quick look on Amazon shows them available at 85psi and 95psi. If you can't find 90psi, go with the 85psi - it will give you an earlier warning.
    I like them so much, I put them on my FoldnRoll also. Nice to be able to just take a quick look and know the pressure is good.
