holstein13 wrote:
rgatijnet1 wrote:
In my case, since I checked my tires when cold, before I got on the road, (This may not be a convenient thing to do based upon your location or time of day.) if I noticed a tire that was LOW at the first rest stop, I would know I have a problem with that tire. (I'm not sure how you would "know" you have a problem. I think you would ASSUME you have a problem. But I certainly would not ASSUME I had a problem. Maybe some kid just let some air out.)I may put air in it to get to a service center, but I certainly would not ASSUME that the tire was now safe and would remain safe/perfect the next day.(Sounds to me like you are making other assumptions. Not me. I'll inspect the tire and keep an eye on the tire pressure monitor and I'll figure out using facts whether or not I have a problem.) If it was a dual, I would also be concerned about the other dual that had to take up the additional weight to compensate for the tire that was low.
Is this the same monitor that did not warn you the tire was losing air until you noticed it at the rest stop? :B
