As for me, I check air pressure before leaving on a trip. I then use my "Ryan Newman - NASCAR" microscopic drill to drill a bleeder hole in the tire. As the tire warms up, the increased pressure bleeds off through the microscopic hole and I arrive at my destination with the same tire air pressure as I started with.
I have various diameter microscopic drill bits based on the beginning and ending temperatures planned for my trip.
I will send you my chart and you may want to adopt my tire pressure solution.
After all, Ryan Newman is a NASCAR winner - occasionally. :)
BTW - the above was all in fun. That scenario actually played out and cost RCR $250,000 plus suspensions and probation.
I check and set pressure before I leave and will do a ball bat 'thump' test and also do a temperature test with an infrared thermometer during stops.
