The outside dual tire stems will face inward, unless an adapter is installed to turn them 180 degrees. Flexible adapters work. Some wont use them due concerns of leaks. I've had them on 3 different motor homes over 18 years and had one leak. It is possible to have solid "U" shaped stems installed, but then you have a problem if you have to move the tire. The outside dual is the one I usually use if I happen to experience unusual wear on a front tire. Camping World sells a solid "U" adapter that screws onto your inward pointing steel or brass stem. Don't have any experience with them.
