sew0177
Sep 05, 2015Explorer
tire pressure
I am preparing to install the eez tpms and went online to the michelin inflation tables. My tires are 275/r80 22.5 load range h with a front axle weight of 10840 and rear axle weight of 18340. This ma...
ClassAGeek wrote:
With all due respect to those who are trying to help, I wish people would do some more research before adding their comments.
The manufacturer's PSI numbers print inside your MH are MAXIMUM values. They are pressures required for a fully loaded coach using the OEM tires. Use different tires or (hopefully) drive at less than 100% loading or tow a toad and you can use lower PSI.
