Having_Problems's avatar
Jul 06, 2016
Tire Pressure
Hi
I have dual tires in the rear of my motor home & obviously 2 in the front
I know front tires are to be set at 65 psi max & rear tires at 80 psi
What is considered a safe range among all 4 rear tires & a safe range among 2 front tires
As it now is 4 rear tires all read different psi but within 5 psi & front tires are within 5 psi of each other
Is this OK????
Or do all 4 rear tires need to be the exact same psi & all front tires the exact same psi????
Please some of that great help
Thanks
Ted
  • Your posts seem to indicate you have a 23 ft. I have a 24 ft. I run 65 in the front 60 in the rears, as per ford door sticker specs. At 80 and 65 I would be bouncing all over the place, I think. Bet your specs are very close to mine. may want to drop those rears down, in my opinion
  • You might want to consider a Tire Pressure Monitor system. Sure takes out the guess work & kneeling down & fiddling with a tire pressure gauge every time. I had a tire pressure equalizer system on our 2002 Shasta Sprite, but decided to go with a full TPM system on our "new" Jamboree. I installed the system from EEZ RV Products & love it! I switch in on about 5 minutes before we plan to take off, it warms up, reads all of the pressures for me while I'm doing other stuff. No getting down on my hands & knees & fighting with the inside tires & all.
    Worth the cost in my book.
    Chris
    Is this OK????
    Not only is it OK, it is to be expected.
    No two tires/wheels are EXACTLY alike.......and most of the time one side will be in the sun and the other side in the shade.
  • fredandkathy wrote:
    I try to keep my tires as close to 65 and 80 as I can. I guess that I obsess a little, but better to be safe than sorry. Myself, I try to keep them within 1#.
    That is not safe.
    Set them to the recommended pressure +/- 2 psi when "cold" (that is after sitting overnight)and then don't worry if some go up a bit more than the others.
    YOU SHOULD NEVER RELEASE AIR FROM A HOT TIRE.....unless maybe you suddenly realize that you put way too much in to start with.
  • I try to keep my tires as close to 65 and 80 as I can. I guess that I obsess a little, but better to be safe than sorry. Myself, I try to keep them within 1#.
