Tom/Barb wrote:
becker wrote:
Question: Presently in Albuquerque.... came in from Houston, tx....getting ready to proceed to St.George,Az.... all tires are about 5 lbs low.... how does temperature and altitude affect tire pressure as I proceed North.... do I need to fill the tires back to normal traveling pressure every morning before I get on the road? Thanks
5 pounds low..... lower than what?
Here is a second method of determining the correct pressure for the tire vs the load being carried.
at each stop during the day check each tire for being hot. if you find a tire hotter than the others, raise the pressure 10 pounds. when they are all hot raise them all.
While I agree that a hot tire can be one indication of under inflation, define hot. It's not something you can readily tell by touch. And if you have a thermal gauge, what's the temp to indicate an issue? 110, 120, 130? And blindly adding 10 psi to each tire, especially a hot tire might not be the answer. Suppose that tire was on the sun side, or on the lower crown side of the road, or the side weight is being pushed to by the wind, or there is a brake dragging issue. Any myriad of things that should not be resolved by blindly adding 10 psi.
The overarching answer to how to set proper psi on any tire for any condition, is to weigh your rig loaded for travel, and set the psi - cold- to the tire manufacturers chart. Cold meaning prior to driving, despite whatever the ambient temperature is. Cold does not mean after you drove for a while, after you rested for a while, adding psi for ambient temp etc. Cold means before you drive on them. Not sure why this always gets over complicated. Fluctuations in ambient temp as well as altitude are already accommodated for by design of the tire - provided it is weighed and set correctly to the chart. Don't over think it and borrow trouble. If you set it cold per the chart before you leave, it will be fine by the time you get to wherever you are going. Of course a good TPMS is always a good idea to keep an eye on things.
