chompchomp's avatar
chompchomp
tire pressure
I have an Itasca Sunova 35j, and posted on the driver's side of the coach it says 80 psi cold all tires. I have 6 19.5 Michelins and on the sidewall it's stamped 120 psi cold. I've always split the difference on the road. If we're at 100 psi all around, we're rolling.
I'm just curious how the rest of you navigate that; I mean 40 psi is a big discrepency. Thanks for any feedback.
  • Weigh it at a CAT scale then look up the numbers on the Michelin site for how much air to put in each tire based upon the weight it has to carry. Make sure all your tanks are filled like they would be for you when you are traveling. Get in all the people and their stuff for the weigh in. I run 88 in the front, 92 in the rear based upon my traveling weight and the Michelin tire pressure charts.
    Edit: The people who make your tires know the most about how much air to put in them.
  • The higher # is with max weight. The 80 is a number to start from. Weight it and you should be around 85+. Higher numbers are just a harsh ride and tire wear in the center. Our 37.3 same tire weight to how we travel was 85 to 90.
  • jdc1's avatar
    jdc1
    Explorer II
    The engineers that designed that RV probably know more about this than anyone on this site.
