I just had new tires put on my class C. The new tires seam to have a bit more flex on the sidewalls then the old ones. The tires say max pressure 80psi for load range E. But the sticker in side the dr...
The original tires that came oem were Goodyear 159. They had stiffer sidewalls. They were stiffer all around. They all said max pressure 80psi on the tires. I've always gone with the what the door sticker said wich says 65 front 80rear. The new tires just seam pretty soft on Front with 65psi in them. Don't want to ruin them.
I have done some work rebuilding the sleeper above the cab from water damage. Added some weight from wood but it couldn't be more then 120lbs.
