As long as you did not weigh , you have to do with the GAWR's.
Then add 5% to the front , because front is seldomly overloaded.
Add 18% to rear GAWR, because back is often overloaded.
Look at the sises of your tires, you give
245/70R10 5G 19.5 x 6.75., I asume its 245/70 R 19.5 and the 10 5G got between it because the computer was thinking to be clever.
So I googled that sise , and because I live in Holland, first an Eng/austr page came up with the better calculation.
The english page with better calculationtop of 2nd page your tire-sises. and as is usual in Europe no different loadratings in one list and a reasonably save calculation for loadcapacity at lower pressure.
Also notice the second loadindexes for speed L =120km/h wich is 1 LI higher. For 130km/80m/h its 135/133M wich I filled in my motorhome tire-pressure calculator .
Here a picture, mind that the American tire date can be a bit diferent , you can find maximum load single and dual on the sidewall.
Mayby also a second loadindex for lower speed.
In next map on my skydrive you can download the spreadsheet with your username by RIGHTCLICKNG and then choose download, and you can fill in the weighed loads once you have them , to see if it gives other advices.
If you also give the GVWR the spreadsheet also gives information if the vehicle is overloaded .
The examples map with LinDens calculatorYour tires are a bit oversised and the original where probably F load with lower maximum load. Then the rimms probably also for lower pressure rated , mayby even 80 psi. So try to look this up.
It might be that your tires may have that 105 psi ( even 10 psi more) but the rimms may not. This would be an extra reason , not to go over the advices on the rig.
