Bikeboy57
Sep 21, 2017Explorer
The rate at which the tire will fill is directly controlled by the difference in pressure between the tank and the tire. Make sure the regulator on the outlet is set to maximum.
I owned a coach that required 130 on the fronts. The porter cable pancake compressor rated for 150 psi filled them just fine
