Tom_Barb
Sep 21, 2017Explorer II
Remember folks, the tire valve core has a basic opening pressure. your compressor must at least have that pressure over the desired pressure to get the air into the tire.
want to prove that? use an old rubber tire filler with a core in it, connect it to your compressor, set the regulator at 0 and slowly add pressure until the valve core opens.
Ive seen them as low as 10 psi, and as high as 80 psi.
