JR45
Sep 30, 2013Explorer
I had my coach weighted at the FMCA Rally in Albany,Or (4 corner wt) and I'm over wt in the rear by 1150lbs and under in the front by 730lbs. In January I got a new set of Michelin 295/80R22.5 XZA2 with a max PSI of 120lbs. With a combined wt of 33,620lbs FR 6,405lbs-FL 6,065lbs RR 10,195lbs-LR 10,955lbs I have to run 105 PSI in the front and 100 PSI in the rear. This is the only way to get a true wt reading and know what PSI to run, money well spent. Must be the new steel and brass radiator and not the way the wife packed the coach.
You need to check your books on the Cummins or maybe someone with a Cummins can tell you. My Cat C9 400 holds 8.5 gallons.
JR
JR
38,776 PostsLatest Activity: May 14, 2026
