Dale_Traveling
Oct 01, 2013Explorer II
I have a smaller 2006 F53 chassis than the OP and only need 80 PSI in the set of Kelley KSR tires to support the maximum axle capacity of the chassis. Running at max sidewall indicated pressure shouldn't hurt the tires but will make for a very hard ride and maybe stability problems. The builders label in the coach will list the tire size, weight class and associated recommended inflation for the maximum axle load. As long as you are not overloaded and are using the recommended tire size those numbers will be safe.
Engine oil for the Ford V10 is six quarts. Last oil change for reasons beyond my reasoning I used seven quarts. Didn't seem to hurt the engine but I was wondering why my mileage suddenly dropped about 3/4 MPG. Will see if that was the cause this weekend while on the road.
38,776 PostsLatest Activity: May 15, 2026
