Roamin_
Apr 14, 2017Explorer
Tire Presure
I need the tire pressure for 8 yokohama motorhome tires. They put 110 psi in the front, 90 in the duels and 80 in the tag. Any tips? Thanks in advance. Oh, tire size is 295/80r
dalenoel wrote:
If you can supply the weight per corner of the unit we can give you an accurate psi. If not by corner then by axle and we can give you an estimate per axle. Still might be low or high based on which side is heavier.
