Roamin_
Apr 14, 2017Explorer
Tire Presure
I need the tire pressure for 8 yokohama motorhome tires. They put 110 psi in the front, 90 in the duels and 80 in the tag. Any tips? Thanks in advance. Oh, tire size is 295/80r
dougrainer wrote:Mr.Mark wrote:
Roamin, with your particular motothome and weight you need:
Front 135 lbs
Drive 125 lbs
Tag 110 lbs.
MM. :R
Curious, I have NEVER seen PSI in a motorhome tire above the MAX of 120. Where did you come up with 135? AND, how do you know what motorhome he has? It is not on his profile or posts.
