Mr.Mark wrote:
Roamin, with your particular motothome and weight you need:
Front 135 lbs
Drive 125 lbs
Tag 110 lbs.
MM. :R
This is not correct! Please do not use this information.
Without information about the 4 corner weights for your coach no one can answer this question. In any case, never inflate the tires (cold) to any pressure than that listed on the sidewall max. pressure.
I see that he said it was a joke but not a funny one to someone who does not understand anything about tires.
Let us know what kind of coach and, most importantly, how much it "actually" weighs. Even if you have the weight from a local truck stop scale this will be a good guide but it's really not going to be accurate unless you have all 4 corners (6 actually with a tag) weighed.
