Ev
Jul 25, 2015Explorer
Tire question
Getting two front tires Michelin XRV 245/70R 19.5 load range F $532 per tire mounted balanced and installed is this a decent price Hankooks came in at $411 I'm leaning towards the michelins.....Any th...
rgatijnet1 wrote:
If you are near Orlando, there are numerous TRUCK tire shops that will come to you and change out the tires. You can even order tires online and have them delivered to you and then contact someone to come and change them out. If you use the balancing BEADS, you can balance them on the spot with no machines needed.
