Does anyone rotate the tires on a class A? I have read many comments about tires but cannot find where this has been addressed. If you do recommend it, how often?
I had the rear duals (22.5 inch rims) off a while back for maintenance. Just fighting with those two and torqueing 10 lug nuts to 600ft-lbs was enough fun for me. I am not going to rotate without a real good reason. Now if I had 19.5" or smaller I would consider it a lot more.
My tires are the same size. they have direction of rotation, not rotating tires, on the steers. If you have six or eight aluminum you could rotate them. I was taken aback when I saw that they did/do put all the wheels in aluminum.
If you do rotate the tires be sure to incorporate the spare into the mix; if you have one. My guess is that rotating tires on a MH is a VERY BIG JOB and virtually no one does it.
Many RVs have different size tires front and rear, so one would be restricted from rotating.
On the other had, I rotate my tires because I have front wheel drive. My fronts wear much faster than the rears, so when they are about half worn, they get moved to the rear and a new set gets put on the front. The rears on mine take for ever to wear, so they get cycled through. I end up buy two tires every third year. This way I can get reasonable traction in the snow.
No reason why you can't. I won't unless I start getting an strange wear pattern on the front and would have the service tech rotate the tires as part of a front end check out or alignment.
