path1's avatar
path1
Tire temp with infered gun
How hot of tire temp readings have some of you gotten on hot days?
Driving in Eastern WA today and checked tire temp and it was 161 on one dual and on other side one tire was 157. Outside temp was 97 and on asphalt road.
Does anybody have a "normal" range?
What is to hot?
  • I was in the Las Vegas area two weeks ago and also checked my tires with a infa-red gun. Outside temp was around 100 degrees. Front tires were 123 degrees with duels at 143 degrees, inside dual ran at 148.
    Tire size was 245-75-19.5 Load Range H. Tire press. cold was front 90lbs. and 95lbs.rear.
