imgoin4it
Apr 11, 2015Explorer
Make sure the pressure is correct and do not worry about the temp. If you take the temp as you drive just use the info, what ever it is most of the time, as the standard. If it ever exceeds the "normal" temp. It will be because the pressure is low or a brake is dragging or maybe a wheel bearing is going bad. Just keep the cold pressure correct and don't worry about the Temps
