Deano56 wrote:
Well, I guess I hit a soft spot, I don't sell used tires, nor do I sell a car with bad brake or ;the front end ready to fall apart, I give them away or throw them out. I don't need that little bit of money, to wonder if they will hold together for someone going down the road. You guys do what youwant
I think you're over-reacting a bit. A serviceable tire, that still has useful life at slow speeds and low weights, is not the same thing as bad brakes or mechanical parts about to fail. One is simply being re-purposed, the other is obviously unsafe at its expected use. Tires are HUGE landfill problems, as not nearly enough get recycled into sandals and welcome mats. Most end up in acre-size piles that catch fire every now and then and burn for three weeks with a noxious, deadly plume.
