dons2346
Jan 30, 2015Explorer
Rollnhome wrote:Bikeboy57 wrote:
Before you shave the tire, you might think about airing it down, breaking it loose and rotating one eighty. It's the first step in the Michelin service manual for an out of round tire. It would be easy to assume that the rotation is to move the high spot to the other side, but that's not the purpose. It is common for the tire not to seat exactly centered. Plus it stretches slightly after inflation. Deflating and rotating simply give the tire a second chance to seat more centered after the bead has stretched.
X2 Rotate the tire on the rim and reseal. Sometimes the wheel and tire vibration can be resolved by repositioning the tire on the wheel.
Good advice here. I had the same condition on a new coach and the problem was a tire that would go out of round at speed. You should have the tire spun up to highway speed and check the runout.
