KCerling
Aug 07, 2015Explorer
Tire wear
I am having some excess tire wear on the front tires of my tow car which is a jeep. My tire guy blames the fact that it is being towed. Have others had this?
rgatijnet1 wrote:mtrumpet wrote:
Then, would it be a correct assumption that the problem might be more prevelant when towing with a Gas coach which would typically have a lot more overhang behind the rear axle then a DP?
I have seen a lot of DP's with large overhangs. Even a DP with a tag axle will swing the rear end a lot which is why some will lift the tag axle to avoid scrubbing those tires during a tight turn.
