paullac
Jul 20, 2014Explorer
richardwise wrote:
You will love the 3010, I have a 2014 model myself. It only seems huge at first. Just remember point the front where you want to go, and the back will follow. I try to not get in a situation of a tight turn in close quarters, but at gas stations, just keep using mirrors and looking ahead, like your head is on a swivel. No levelers on mine, I just use boards and those plastic squares. I have the heated tanks on mine for cooler weather, and a/c heat pump unit. Love the heat pump, saves propane from not using furnace. The only thing I don't have that I would have ordered on it is a gas/electric water heater, and not just gas. But I bought it off a dealer's lot. I did take the uncomfortable to sit on jacknife sofa out, and added 2 small recliners.
As mentioned above, we have a 2013 sunseeker 3100. If you have the factory water heater it is both gas and electric. All newer sunseekers have that standard. The switch inside on the control panel is the gas switch. As for electric: go outside, remove the water heater access panel, get down on your knees, look in the lower left (kind of hidden behind a pipe), there's a small switch there that is the electric switch. Caution: do NOT turn or leave this switch on without water in the tank or you will burn out the electric heating element. By the way, not sure who your dealer is but they gave you a terrible pdi demo for not telling you this when you bought it.
38,766 PostsLatest Activity: Jan 10, 2026
