photobug wrote:
Ordered a set of tireman stems for mine. absolutely impossible to check rear tires the way they were with the little rubber stems. As mentioned above, now it's a breeze. Got even lazier and installed a set of tire pressure monitors. Now all I have to do is check them for accuracy once in a while. Takes 30 sec to cycle through all the tires and I can do it sitting on my butt. Glad I did this mod. too bad they can't get my front hub cap back on.
On my first MH I hated the cheap looking clip/pound on hub caps , so I removed each front wheel , sanded them down abit, rattle can primered them then rattle can painted them .
They actually turned decent.
Left the rears on just took a little longer and did the same to the outer wheels.
I just taped off the tires,wheel well and side area of MH when I painted the rears.
