KendallP's avatar
KendallP
Tires - The 10 Year Rule
Hey gang,
Regarding big, DP tires...
I know most adhere to this rule and some prefer to replace tires within 7 years or so of date code. Others replace the steers every 5 and the drives every 10. Others still will have them all removed and the interiors inspected before giving up on them. Etc, etc...
I'm inclined to err on the side of caution, myself, but I'm curious to hear your thoughts. And to see if anything has changed in the last 5 years since this thread.
So given...
6 - Toyo M-154 265/75R22.5 tires with 10,000 miles
Installed March of '13, but approaching 10 years of date code
Babied and covered most of their lives, in beautiful (where visible) condition with no checks
Entire lives in Santa Cruz with a very mild climate. Last couple of years undriven and parked without the jacks down and uncovered with driver's side facing south (the sun... and Central California coastal fog)
On a Freightliner/Cat chassis running fairly close to GVWR / tire max
Replacement cost - $3,100
What would you do?
EDIT: Here's a good read posted by dougrainer 5 years ago. The study indicates 6 years is the maximum for safety. Though it appears to be general tire specific. No mention of commercial, one way or the other.
http://www.ntsb.gov/news/events/Documents/2014_Tire_Safety_SYM_Panel_4b_Kane.pdf
Also... some seem to indicate that commercial truck tires are more robust than RV tires, despite the size. I can say this... the Toyos are spec-ed at 99 lbs vs 90 for the OEM Michelins. All that said... they also undergo more severe punishment.
  • wa8yxm wrote:
    I'm told that in some states tires over 8 years are considered hazardous.
    (NOTE I have made no effort to verify that. I replaced the tires shortly after being told that for other reasons. (They needed it) but that is what I was told.
    I've seen both 5 and 7 as the recommended replacent intervial
    Just now the motor home is in a bone yard (Long story. but not unhappy)
    And the car the insurance check paid for in full.. Tires are like 7 MONTHS old.
    Wow!
    I feel like that rig has been in your signature the entire time you've been a member here, no?
    When did this happen?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
  • I would replace them. $3100 sounds like a lot, but when you figure out how much reparing all the damage done by an old tire blowing, it's cheap.
