dcbrewer wrote:
timmac wrote:
enblethen wrote:
Not sure who told you that rear end is not adjustable.
A good shop can do this.
They can install wedges
They can check and move spring centers.
Be surprised what happens with a full alignment.
Yes my rear axel was off on the drivers side, that was why my motorhome went down the road with the back slightly off according to my wife that followed me one day, they had to unbolt the leaf springs and with a machine it adjusted my rear axel straight with the frame and the front were adjusted as well.
No shims or wedges, just adjusted straight.
 if that's the case, was the center bolt broke? don't see how it moves without the center bolt being sheared.
Not sure mine has a center bolt, will have to check, it was only off a little.
Its a 2007 F-53 chassis if someone knows if it has a center bolt, the alignment guy never mention anything wrong other than just need adjusted, and I did see him adjust the rear axel so it was off.
