- William_BExplorer
But your tire blew out at 1 year old. So it sounds like you should replace your tires every 363 days in that case.
My point is the folks that have had blow outs are not quite as apt to extend the time between tire replacement, as those who haven't. I really thank you for your very astute observation. - jwmIIExplorer
DanTheRVMan wrote:
pappyralph wrote:
What if,( my motorhome )tires have always been stored inside building, with pads between cement & rubber, only outside when on trip. Has got to be longer then about 7 years.
You do not understand
Sunlight exposure does not matter - 7 year life
under inflation does not matter - 7 year life
Over loaded MH does not matter - 7 year life
High southern heat when driving does not matter - 7 year life
etc. etc. - 7 year life
Respectfully, I disagree with you. He understands perfectly that with reasonable care which includes preventing moisture from coming up around the tires from the ground, storage indoors, close inspection for cracking, proper inflation, not scuffing the sidewalls on turns, not left stored in standing water, kept out of direct sunlight, etc, that their is realistic potential for safely running your tires beyond the 6-7 year time frame. The longer this period is the more intense your tire maintenance and observation should become.
Even with all of this attention the day to change your tires out will inevitably arrive. - NAUTIQUEExplorerAnyone know what type of $'s you're talking in having them professionally inspected?
- Mr_Mark1Explorer
DanTheRVMan wrote:
Mr.Mark wrote:
I certainly understand what you are saying. This is how it was explained on a tire thread a while back.
Tires are like a bowl of spaghetti.... the thread and belts are the noodles and the rubber and emollients inside are like the gravy (sauce). When the tires are heated the gravy mixes well with the noodles and everything is copacetic. Tires sitting will kill them.
MM.
I suggest some materials engineering courses instead of good old boy gravy stories
abused tires will need to be replaced less than 7 years
well treated tires will last longer than 7 years
temps, stresses, UV exposure, abuse, etc will all affect tire life
Being Italian, I kinda liked my tire reference story :B
Tires sitting in a garage on boards, etc. is not good tire maintenance.
And I agree with you and the poster that says having them inspected professionally is the way to go.
Safe travels,
MM. - DanTheRVManExplorer
msmith1199 wrote:
J-Rooster wrote:
My last set of Michelins I replaced after 10 years! I don't get tire advice from the RV.Net tire Inspectors. I had my tires broken down off the rim every year after 5 years and inspected inside and out by a certified tire expert at my tire shop! It gives me peace of mind and I know exactly what I'm driving on!
Best answer!
EXACTLY
If inspection by tire experts say the tires are kaput at 5 years you need to replace them at 5 years
If inspection by tire experts say the tires are kaput at 9 years you need to replace them at 9 years
Simplistically repeating 7 years will either waste money OR PUT YOU AT RISK OF A BLOW OUT - msmith1199Explorer II
William B wrote:
I'll bet this breaks down to who has had a blowout and who hasn't. We had a front tire blow out on 1 year old GY's, did thousands of dollars worth of damage, but I was able to get it safely to the side of the road. I was lucky there was no one right beside me. So for us, it's 7 year max and never again a GY tire. By the way after a fight with GY they finally paid for everything. Also as Mr Mark said it is more important to drive on the tires regularly and keep them properly inflated than most anything else.
But your tire blew out at 1 year old. So it sounds like you should replace your tires every 363 days in that case. - msmith1199Explorer II
Best answer! - William_BExplorerI'll bet this breaks down to who has had a blowout and who hasn't. We had a front tire blow out on 1 year old GY's, did thousands of dollars worth of damage, but I was able to get it safely to the side of the road. I was lucky there was no one right beside me. So for us, it's 7 year max and never again a GY tire. By the way after a fight with GY they finally paid for everything. Also as Mr Mark said it is more important to drive on the tires regularly and keep them properly inflated than most anything else.
- J-RoosterExplorerMy last set of Michelins I replaced after 10 years! I don't get tire advice from the RV.Net tire Inspectors. I had my tires broken down off the rim every year after 5 years and inspected inside and out by a certified tire expert at my tire shop! It gives me peace of mind and I know exactly what I'm driving on!
MM.
38,778 PostsLatest Activity: Jun 10, 2026
