William_B
Jan 01, 2019Explorer
rgatijnet1 wrote:
I guess it is possible but I can't even imagine how a toad can break loose unless someone tried to cut corners. I mean you have to have both arms of the tow bar fail, as well as both tow chains, or perhaps your hitch broke loose and the entire tow bar came loose. In that case, you still have the two tow chains. I never trusted the hooks on the tow chains and I replaced the ends with screw on links. These will never come loose and will hold the vehicle if everything else fails. On my rig, I would have to have four things fail at once for my toad to break loose. This seems highly unlikely.
I wasn't going to get in this discussion, but my FIL had his toad come completely off the rear of his motorhome in the Badlands. It was a Roadmaster tow bar and base plate, the older style where the safety cables attached to the base plate. The entire baseplate sheared off and the vehicle took off across a field thankfully to the right away from the highway not across it. We saw this with our own eyes.
