getgoin
Mar 28, 2016Explorer
Toad Brake laws
Hello all.... So we have the class A and the Subaru stick shift, now it's time to set the two up. I got a hold of friends in CO, I'm in CA, they tow a Subaru like mine. CO law does not require a br...
mowermech wrote:msmith1199 wrote:wa8yxm wrote:
Two comments:
In the past (some have been fixed) I've viewed several of the "Do you need brakes on your towed" web sites and found errors.. For example for many years many sites said "MICHIGAN: NO" this is because there is no specific rule about brakes on a car in tow.
HOWEVER the definition of a "Trailer" fits a car in tow like a surgical glove, In fact a true trailer does not fit as well as a car in tow believe it or not, And trailers (over xxxx pounds) do need brakes.
The above is traffic law, which may be Criminal or civil depending on the state.
Page two: Civil (Liability) Law.
It has been shown that a proper aux braking system can reduce your skid distance by as much as 30 percent (Source US Gear). Even if it's only 10 percent (Much more likely) here are some figures
20 mph on clear dry "Reference" pavement you skid 22 feet
40 Mph it's 44 feet
60 MPH (Common for RV's on Freeway) 191 feet.. yes 191 feet.
So let's add 10 percent.. that 191 is now about 210,,,
You panic stop.. no aux brakes, wind up 3 feet in front of the rear bumper of the car you hit... (Aux brakes would have stopped you 17 feet behind the car)
RECKLESS DRIVING.
A trucker in Ohio, many years ago, tried time and time again to pass a poke-alongus, there was never any contact between vehicles, never any danger to the Honeralble Mr. Pokey attorney at law.. He sued, got half a million dollars b ecause he "Felt Threatened" How much more so when you hit the guy.
A smart lawyer gonna make you WISH you had brakes on that towed.
Here is the Michigan law defining trailer:
"257.73 “Trailer” defined.
"Trailer" means every vehicle with or without motive power, other than a pole-trailer, designed for carrying property or persons and for being drawn by a motor vehicle and so constructed that no part of its weight rests upon the towing vehicle. Trailer does not include any implement of husbandry."
And although upon first glance you may think it would include a towed motor vehicle, all elements of the statute must be present. Note the part that says, "designed for carrying property or person AND for being drawn by a motor vehicle." I put the word AND in caps because for some to be a trailer the statute says it must be designed to be towed. That excludes cars as they are not designed to be towed. This statute is defining a trailer not a car.
Montana has the same law, nearly identical, except the word "persons" is not there. A trailer is not designed to carry "persons"! In fact, it is illegal for a "person" to ride in a "trailer"!
Is it legal in Michigan to ride in a Travel Trailer? How about a Utility Trailer?
Hmmmmm...
