I have a hitch on my newly acquired Alfa Gold. I want to tow my 2001 Dodge 2500 pickup that had a hitch mounted on the front, (yes front). I want to know if I can tow the Pickup with a tow hitch to to...
Your MH will pull the weight of the pickup fine. The few nickels you will save by using some home grown system instead of factory base plates and a good tow bar like the Falcon II or Blue Ox does not make good sense. Think about the liability of using a system that is not tested or designed for the application you are thinking about.
