10forty2
Jun 26, 2015Explorer
TOAD Question
Going straight to the experts on this one.....:B instead of trying to hunt around for bits and peices of information that may or may not exist. Looking into purchasing a daily driver/TOAD. Prefer ...
naturist wrote:Tom/Barb wrote:
We tow a 07 wrangler, place the transmission in park. place the transfer case in Neutral, and go. you can place the transmission in neutral, but it does nothing extra for safety.
Be certain that you disconnect the battery. and place the key in the (on) position to unlock the steering. We used the "Cooltech" wiring harness. and a quick disconnect switch on the battery positive post.
this will be the fifth year we have been towing this way. no problems.
Long trips where I have any doubt I might be required to back up, I load it on a car hauler and stop worrying
This is possibly important here: Jeep says put the transmission in park, not neutral. I have a bud who made the mistake of putting it in neutral on his Jeep, and it burned up his transmission. Evidently, there was just enough torque applied through the transfer case even though it was in neutral to turn the transmission just enough to cause severe damage.
Secondly, it is MUCH safer to put the battery disconnect on the negative/ground terminal of the battery. If you insist on putting it on the positive terminal, you must be VERY careful that there is no way for an errant wire, rod, or ANYTHING to EVER cause a short between the body (or anything else) and that switch. Most battery disconnects fit the negative terminal much better than the positive one for this very reason.
