Tow Dollies Model 77T Model 80THD
Vehicle Tread Width 40” – 77” 40” – 80”
Max Width at Front Doors 75” 78”
Overall Width 99” 102”
Overall Length 121.5” 121.5”
Height at Fender 26” 26”
Ground Clearance 6.0” 6.0”
Weight 450 lbs. 551 lbs.
Tow Dolly Gross Vehicle
Weight Rating 3,000 lbs. 3,500 lbs.
Actual Cargo Capacity 2,550 lbs. 2,950 lbs.
Maximum Gross Weight of
Vehicle to be Towed 4,250 lbs. 4,900 lbs.
Tire Size (Trailer Service) ST 205/75D 14" 6 Ply Rated
Coupler Size 2” 2”
Coupler Class SAE 2 /3,500 lbs. SAE 3 / 5,000 lbs.
www.mastertow.com
This chart is on "Master Tow's" website. I use the model 80THD and it clears vehicles up to 78" wide at the doors. I think you have the narrow model and need to do your homework. The capacity of the dolly is Ok. It is the width you need to look at. Also be advised that if you fail to secure the steering wheel from turning, it will allow the dolly tray to pivot into the body because of the front wheels turning. It will also loosen the tie down straps if the steering wheel is not locked.
