strudeau wrote:
tsjoshua wrote:
Do you have diodes installed for the brake lights?
The wiring is all "plug and play" or in-line with the existing toad wiring. The wiring set up works great when hooked up without the Air Force One. My guess is that when the brakes in the Toad get applied by the Air Force One, the wiring is conflicted because it is also getting a signal from the Coach.
You need to have someone who knows what they are doing install a diode in the brake lines to prevent conflicting signals. Diodes are basically one way valves, that let electricity go one way but won't let it bleed back thru the other.
