danddclydes wrote:
Has anyone on here towed a horse trailer with their coach? If you have do you know if it is possible to have a double-duty trailer that I could use to move a small car when not being used for horses? I know it is a strange question but several times a year I will use my coach to move horses to out of state shows
No, its not a strange question! On your coach, the UVW (empty weight) is 26,100 lb. Once you load up your cargo, you could get up to your GVWR of 31,000 lb, althought I doubt it. Your GCWR is 33,000 lb. If you were to fill up your coach with almost 5000 lbs of cargo, and we all know that some RVers get carried away, you could only haul a trailer weighting 2000 lbs. When you spec'ed, you should have considered this. You would have been far better off spec'ing a Dynamax DynaQuest. Just what does one Clydesdale weight - and two in one horse trailer? Bet you'll be up around 5000 lbs or higher.
