Second_Chance
Mar 29, 2017Explorer II
Sounds more like a technical (hardware) failure in the GPS, Doug. Put another GPS beside it if you have one. If the original still doesn't get satellites and the "control subject" does, Houston - you have a problem. The next step I would take would be a hard reset on the unit (sometimes from the system menu, sometimes with a paper clip in a little hole). If that doesn't fix it, it has failed.
Rob
Rob
