lindalp's avatar
lindalp
Top RV manufacturers?
I would appreciate your personal opinions, of the top quality makers of class c rv’s.
Sounds like Winnebago is the best, and Thor the worse.
We are looking for a good quality used class c. Which makers should I look at after Winnebago?
  • These are some of the best class Cs ever made. Might be hard to find a good used one, though, as people tend to hang on to them until...
    Lazy Daze RVs
    Rob
  • Triple E and Coach House come to mind. If you’re considering used, take a look at the Bigfoot ( made in Canada). They are no longer producing motor homes, but those were good units. Our “used” Bigfoot has one of the highest fresh water capacities of the class c units(if that is important to you), and is well insulated for cold weather use. Of course insulation works “both ways”....easier to cool in “hot” climates. All of the above were/are “pretty pricey” units though.
    Most of the “smaller” class c’s have the Ford chassis. Try for the E 450 chassis, gives a little more suspension for the heavy unit, and “generally” has a lower gear ratio rear differential.....which gives greater towing capacity (for toads or boats), and better hill climbing performance ( nice in mountainous terrain and some campgrounds)
  • I think you will find condition is more important than the manufacturer.
    A well maintained Thor in good condition is a better choice than a poorly maintained and beat up Winnebago.
    Take your time and look at everything, when you find something you like, inspect it or have it inspected.
    Use your search as a learning experience.
    Enjoy your travels.
