Ava
Oct 03, 2020Explorer
If you want a simple torque multiplier kit that easily removes my 450# lug nuts, look at Amazon. The kit I have was under $100, has one inch drive with several sockets and packs up in a small case. It has a hand crank that turns 58 to1 ratio. The unit is rated up to about 3500 ft lbs of torque. You do need to use a normal rated torque wrench to tighten the nuts.
