klutchdust wrote:
"Since the primary duty of a trailer tire is supporting a vertical load, rather than gripping an automobile through turns, trailer tires do not have to be dynamically balanced like passenger car tires do. Steering and cornering are less of a concern on a trailer tire than they are on an automotive tire."
I haven't balanced any of my trailer tires nor was ever asked to have it done by the tire shops. Is there a difference in a balanced tire? Asked this question, and read
multiple responses from tire manufacturers etc. Interesting.
I absolutely insist on tires for anything, including trailers to be balanced. Balancing has to do with ride quality and vibration, and if you have out of balance wheels, its like the trailer is being driven on a dirt or gravel road 100% of the time. It loosens electrical connections, it makes things move around in cabinets, cabinet doors to come open and things to fall out, can cause water leaks, and generally wreak havoc on the trailer and everything in it. You also suffer from additional suspension wear, bolts and bushings, shocks if you have them, all take a beating with out of balance tires.
Airstreams for example, will pop rivets if they have a rough ride, and so Airstreamers are very attuned to having the smoothest possible ride for the trailer.
Wheel balancing has nothing to do with cornering ability on any vehicle, but has everything to do with the life of your trailer. Think what condition your house would be in if you suffered minor earthquakes every day? Cracked sheetrock, cabinets coming loose from the walls, etc.
Charles
